Sponsored by:
Sponsored by:
Odd Charging Issue
Old Jan 10, 2009 | 04:26 PM
  #26
FubarI33t's Avatar
The FSM says faulty ACG. So i guess new alt for now.
Old Jan 10, 2009 | 06:41 PM
  #27
FubarI33t's Avatar
Shady. where is the batt fuse?
Old Jan 11, 2009 | 03:21 PM
  #28
FubarI33t's Avatar
I replaced the Alt. the 18= volt went away. but still no charge. ran a wire from Batt terminal on Alt to battery. it seems to be stable. but at throttle only 12 volts. under full load. 10. and the lil red light is always on.
Old Jan 11, 2009 | 06:16 PM
  #29
Where are you getting these alternators from? Are they stock replacements? Have you had them check it on the machine before installing it?
Old Jan 11, 2009 | 06:21 PM
  #30
FubarI33t's Avatar
stock replacement. new(rebuilt) this car has so many wireing issues.
Old Jan 11, 2009 | 10:36 PM
  #31
the battery has fuseable links in that little black box by the battery. the reason it is saying low voltage after that wire is installed is due to the fact its back feeding to power the dash stuff. there are 2 wires connecting in the harness by the battery. they are 12 ga. and white. if you follow the wire from the alt. upward, you will see the juction near the batt. its kinda hokey and usually corrodid. i took the white wire from under the dash and routed it to my maxi fuse panel under the hood. that way it feeds straight from the battery. then the alt only has one 4 ga. wire up to the batt via a large 120 amp breaker. i wish i was better at pix, but i could draw the thing up for you.
Old Jan 12, 2009 | 05:57 AM
  #32
FubarI33t's Avatar
Ahh. I don't have Fuse links anymore. I installed a 98 pontiac box. it has maxi fuses. i have 3 60's and 2 30's. there all good.
Old Jan 13, 2009 | 04:59 PM
  #33
i wish i had one more spot, mines only a ebay 4 fuse holder, used to have a digital readout, until my alt hit 18v and melted the readout
Old Jan 13, 2009 | 05:02 PM
  #34
FubarI33t's Avatar
mine is cool. 5 large. 9 small. bottom pops off for all the accses to wires you need. it's long. and not sqaure. has a shunt plug. pull that out. all the smalls loose power.
Old Jan 13, 2009 | 08:08 PM
  #35
dang take some pix
Old Jan 13, 2009 | 08:27 PM
  #36
FubarI33t's Avatar
tomarrow i'll post a pic.
Old Jan 14, 2009 | 01:47 PM
  #37
FubarI33t's Avatar
6 small. srry been awhile since i've actuly looked at it.
Attached Thumbnails Odd Charging Issue-p_00082.jpg   Odd Charging Issue-p_00081.jpg   Odd Charging Issue-p_00080.jpg
Old Jan 15, 2009 | 07:02 AM
  #38
cool, it looks factory too!
Old Jan 15, 2009 | 07:21 AM
  #39
FubarI33t's Avatar
94-99 grand am's should have them. i should of mounted it parralel to the fender. but space is limited with such a bigg fckin battery
Old Sep 2, 2010 | 04:30 PM
  #40
CWHammer's Avatar
Under My Car... brb
GM 1 wire alt in for over a year and running strong. The alt doesn't charge unless the rpm is over 860. Very easy install too.
Pipsqueak
Jun 23, 2014 10:10 AM
Pipsqueak
Apr 24, 2012 09:49 AM
jk11blueboi
Jan 26, 2010 01:08 PM
SHADY280
Sep 22, 2006 08:08 AM
fairladyVT
Mar 21, 2005 12:04 PM
