240Z, 260Z, 280Z Brakes, Wheels, Suspension and Chassis Discussions related to performance suspension, wheels, brakes and chassis.
added a 7/8" sway bar
Old Sep 6, 2004 | 10:32 PM
While rolling around under a '86Z I noticiced that it has a 7/8" sway bar. Bought it for $10. It is 1" wider hole to hole so I bent each end in 1/2". It mounts differently enough to make brackets. It also doesn't drop down far enough to clear the oil pump. The brackets are 1/2" thick steel. 2 1/2" wide by 4 1/2 " long. The bolt pattern is over 1" and back 1 1/2".
Attached Thumbnails added a 7/8" sway bar-%2410-swaybar.jpg
TheShanMan
Mar 8, 2014 03:25 PM
auxilary
Jul 28, 2003 05:44 PM
mescalinedreamz
Jul 10, 2003 09:34 AM
mescalinedreamz
Jul 6, 2003 12:26 PM
CrazyLotusTT
Jun 21, 2002 09:30 AM
