240Z, 260Z, 280Z Brakes, Wheels, Suspension and Chassis Discussions related to performance suspension, wheels, brakes and chassis.
Differential hitting
Old Mar 30, 2005 | 08:36 PM
Well I broke the rear diff mount. The choices are get a new one and break it or get a solid mount and turn my car into a vibrator. Solution, a differential "snubber". I cut two pieces of 1x1 angleiron 3 inches long. I had to trimm 1/8 off one edge. I spaced them about 1/8 from the inner edge and welded them to the outer piece. This allows dampening of the diff and limits the movement under hard use.
I am celebrating two years with Zdriver and I appreciate everyones help.
Thanks, Tom
Old Apr 1, 2005 | 03:13 PM
jmanz6's Avatar
Nice design, should work pretty well, but will also make a bad sound when it hits the snubber. It should hold though. I was going to weld my rubber mount solid, but changed my mind and just got a new one for now.
Old Apr 2, 2005 | 09:26 PM
I took it out today and I am very pleased with it. There is an almost unnoticable thunk on hard shifts but the SuperTrapp drowns it out. Also seems like the torgue is getting to the wheels a lot better than stock. Still very smooth under easy driving.
JAyD_917
Dec 2, 2013 05:38 PM
aruiz714
Jan 30, 2013 12:22 PM
FubarI33t
Mar 29, 2008 03:57 PM
TTZ32
May 29, 2006 04:23 PM
jeffs2fast
Apr 13, 2005 06:38 PM
