91' 240sx problems
Old Oct 8, 2005 | 11:45 AM
needingZ32's Avatar
91' 240sx problems
I gotta a 91 240sx, im having problems. I hit some water one night, and now when ever i hold it at a constant RPM or idle it sounds like a v8 with big a cam. Would anyone have an idea on what would be causeing this. Would it just be my mass airflow sensor? or more? Thanks for your time and help..........
Old Oct 8, 2005 | 11:22 PM
emo236's Avatar
confuzed member
try pulling your plugs and cranking it a few times. You may see some water spit out of some of the cylinders. Also, examine the plugs to ensure none are fouled. MAF might be damaged and faulty too.
Old Oct 16, 2005 | 12:04 AM
Check the TPS, dry the connector and also check your distributor and see if moisture got in there. Might need a hair dryer to dry things out if it's wet. Other than that, it could be a vacuum leak. As another check, when your maf goes bad, generally you can't rev the engine above 2000-2500 revs before it spits and sputters.
Old Oct 16, 2005 | 07:50 AM
CanyonCarver's Avatar
Jack Of All Trades
2nd on the dizzy cap. They're known to both; get moisture inside when cold water hits the hot cap..... and they're also known to crack allowing an arc path to the housing. The simple thing is to put a new dizzy cap on especially if it's old.
You can do a resistance check on the maf to see if it's working properly.
If it was real recent, you might have water in a connector causing it to short out. Just give it time to dry out.
The worst possibility is that you ingested water into the motor and partially hydrolocked it. A compression check might answer that since a cylinder with a bent rod would have lower compression.
Good Luck
ZXT83
Sep 8, 2010 05:17 AM
Habitjr21
Other Cars
Jan 11, 2010 09:54 AM
napoleonzheking
Oct 31, 2008 04:17 PM
Ryan280
Mar 30, 2007 12:55 PM
benderzjamez
Other Cars
Jan 10, 2006 06:38 AM
