Boost guage stopped working
Old Sep 2, 2010 | 05:49 PM
MWJ95's Avatar
what do i check first?
Old Sep 2, 2010 | 06:14 PM
power + ground if its not lighting up and if its not reading find the vacuum line prob needs to be replaced if this is a mechanical guage
Old Sep 2, 2010 | 07:52 PM
http://s95014253.onlinehome.us/63136/176022.html
Here you go
Old Sep 2, 2010 | 08:06 PM
You are an intrawebz wizard!
Old Sep 2, 2010 | 08:17 PM
I actually found that site while looking up info on the Z32, I read the Z31 section as well lol
Old Sep 3, 2010 | 04:49 AM
Nothing like spoon feeding
Old Sep 4, 2010 | 07:43 AM
MWJ95's Avatar
IT lights up and goes strfaight to 6 psi and when the turbo kicks in ,it doesnt move.
Vaccum hose??
Old Sep 4, 2010 | 09:58 AM
Ok that sounds more like connector corrosion to me.
Old Sep 4, 2010 | 07:29 PM
do you have vacuum readings on that that gauge or just boost? are you pushing more the 6lbs? When you start the car what does it read? Give us more detail on whats happening. Are you stock?
Old Sep 5, 2010 | 07:16 AM
MWJ95's Avatar
Im all stock, When I crank the car up u can hear the turbo turn on but the meter still reads -1 instead of like 6 or 7 or whatever the normal is.
Old Sep 5, 2010 | 09:33 AM
So, the car is running and at idle. You are complaining because the meter is -1 when idle in the driveway????
http://www.atlanticz.ca/zclub/techtips/turbo/index.html
http://www.atlanticz.ca/zclub/techti...turboinfo.html
Old Sep 5, 2010 | 06:58 PM
MWJ95's Avatar
no im in 2nd gear doing 35 and i hear it kick on but the gauge doesnt move
Old Sep 5, 2010 | 07:31 PM
you checked the vacuum line and power terminals? Just 3 things you gotta check or could be a cheap old gauge
Old Sep 8, 2010 | 07:49 PM
AZ-ZBum's Avatar
Turbos don't have an on/off switch.
What does your gauge read when the engine is off, but the key is in the ON position?
What does your gauge read when the engine is on and idling?
What does your gauge read when you are accelerating hard in gear?
What does your gauge read when you are cruising at a steady 45 in 4th gear?
Old Sep 10, 2010 | 07:23 AM
MWJ95's Avatar
-1 for all of the questions
Old Sep 10, 2010 | 08:19 AM
If it's at -1 all the time, why did you say it goes to 6?
And have you heeded all the advice about checking the boost gauge / vacuum lines??????
Old Sep 10, 2010 | 01:06 PM
whats the brand of the gauge?
Old Sep 10, 2010 | 03:24 PM
^^^ I think he's still using the stock one?
Old Sep 14, 2010 | 07:53 AM
AZ-ZBum's Avatar
Then stop being an idiot and do what was already mentioned.
CHECK THE VACUUM LINES!
Old Sep 15, 2010 | 06:44 PM
MWJ95's Avatar
dude i get confused easily!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 15, 2010 | 08:14 PM
Maybe the Internet is not a good thing for you.... Just playin
mjoseph229
Jul 20, 2015 12:52 PM
linkovich
Dec 31, 2014 01:47 PM
megaZ
Jul 26, 2014 02:11 PM
worder
Jun 18, 2013 06:23 PM
jtmny1999
Apr 3, 2003 07:40 PM
