Motorsports This board is for Z Racers who compete in Autocross, Road Racing and Time Trials. Focus will be on car set up and modifications. Event coverage, and race parts for sale or trade.
tire and wheel sizing
Old Jul 3, 2003 | 06:10 AM
hades's Avatar
O.K. This subject has been beaten to death, but I'm asking again for posterity. I'm still on a wheel buying kick
On my EP 260, I can run a 15x7 rim. I can fit a 23x9.5x15 Hoosier on a rim of that size. The question then is, will these tires fit in the stock wheel wells? (I have coil-overs so the spring perch size is slightly reduced). 225/50/R15s fit in there fine and 225 mm seems to calulate out to 8.86 inches, but I never met a 225 tire that was 225mm wide - does the same reduction apply to race slicks as well? If the 9.5's will barely fit, is there an offset that will make them fit better?
On the other hand, anything has to beat the Z31 wheels with dead Kuhmos.
Thanks in advance!
-Lukas
Old Jul 3, 2003 | 11:31 AM
Spudz's Avatar
Lukas,
Yes, the 9.5 " cantilevers will fit your fender wells. You will have no problems
with the inside of fender , but will have to roll the outer fneder lips. I am running 225/45/15 Hooiser RS03's and they have a tread width of 9.5" 's on 8" wide wheels.
The cross section is a little wider then that
then that. They have a diameter of 22.5".
I have a few pics of guys running lowered cars with the 9.5 cants I will try to post later today.
BTW.. I am using a 0 offset wheel.
Old Jul 3, 2003 | 12:29 PM
tube80z's Avatar
Lukas,
You can go to www.darcyandcary.com/crazy and look at the pictures of the green 240z. It ran 20x9.5x13 tires on 13x7 wheels. The offset was such that they had about 3/8 clearance to the strut. Seeing how you'd be running 15s you might be able to keep it under the fenders but I wouldn't count on it.
Cary
Gingie
Feb 2, 2014 02:04 PM
280zx79
Oct 20, 2009 08:35 PM
rjc280z
May 26, 2006 11:11 PM
HDPD350Z
Jan 16, 2006 02:35 AM
rjc280z
Aug 7, 2005 04:54 PM
