350Z Performance / Technical Discussions related to Turbo charging, Supercharging, Engine, ECU, exhaust, and etc. performance enhancements and Techical related.
power loss?????
Old Jan 11, 2004 | 05:22 PM
Cw2435's Avatar
power loss?????
I lose all my battery extrememly fast. We have narrowed it down to the alternator isn't putting out enough. I have been told you can exchange it w/ a gm alternator. what i need to know is if you have to rewire it or you can use the same wires. and if you can mount it on the regular mount, and if there are other modifications that have to be made?
thanks
Old Jan 11, 2004 | 06:38 PM
91zxtt's Avatar
If you have a 350Z then it should still be under warranty. Why not just replace it with the factory one and have them pay for all the parts and labor?
Old Jan 11, 2004 | 07:49 PM
Cw2435's Avatar
it is a 1982 280zx
Old Jan 16, 2004 | 01:16 AM
Riz Z Speed's Avatar
Administrative Brown Guy
Originally posted by IZwutumean
why is it posted under Z33 forum?
Good point.
Is it me or does this seem to be a trend lately.
Old Jan 16, 2004 | 09:30 PM
I think that it looks so wide is because the hood line is so much higher. That and the angle of the pic might have something to do with it.
Old Jan 16, 2004 | 10:31 PM
91zxtt's Avatar
Not to sound like I'm not interested, but......getting back to the original question. Check your battery terminals, especially the ground. If you have a poor ground it can, and generally does, effect the charging system. Check the the wires haven't come loose from the alternator. You can usually get a decent reman alternator for $60-$80 bucks after core return. Check that you have plenty of water in the battery also.
Old Feb 14, 2004 | 01:34 AM
Actually, you were correct IZwutumean. The Z33 is wider than the Z32.
Wheelbase numbers put the Z33 at 104.3 in. and the Z32 at 96.5. The width for the Z33 is 71.5. The Z32 measures 70.5. The length of the two is even closer with the Z32 coming in a hair longer by .1 at 169.5. More headroom is available in the Z33 (38.2coupe, 39.2roadster vs. 35.5 Z32) but there's less leg room (42.6Z33 vs. 43.0 Z32) it's very slight though. The Z32 is lower at 49.4 as opposed to 51.9. The Z33 Roadster is an astonishing 39.2 inches in height however. Losing the roof affects the overall height, but I'm sure most of the loss is at the roof level, rather than height off the ground. At least Nissan somewhat addressed the weight issue of the older Z32 when building the Z33. The Z33 comes in a couple hundred lbs lighter. The Roadster however gained it all right back to Z32 standards of @3400 lbs. They even managed to improve the fuel economy despite the larger engine. Z32NA 17/25 vs Z33NA 18/26. 18 being lowest for Auto Roadster and 26 being best for MT Coupe. Of course the larger fuel tank helps, 20 vs 18.7 Gallons.
Since looking at the numbers and realizing how close both cars are in dimensions, I still attribute the wider looking stance to the higher hoodline and fenders.
Old Feb 14, 2004 | 11:54 AM
emo236's Avatar
confuzed member
they may be lighter and have better gas mileage...but....91, fill em in here.
Old Feb 16, 2004 | 10:04 AM
91zxtt's Avatar
Such as, "you can't pollish a turd."
Better late than never is what i always say.
Old Feb 16, 2004 | 07:34 PM
emo236's Avatar
confuzed member
ROFL!
Old Feb 22, 2004 | 08:28 PM
craZed's Avatar
the angle as well,notice the white z32 in the corner compared to red z32 in middle.looks bad azz
Old Feb 22, 2004 | 10:01 PM
White Z32?
What pic are you looking at?
If it's the one in my sig, that's a silver Z.
Old Feb 22, 2004 | 10:33 PM
emo236's Avatar
confuzed member
picky picky!
vg30de
Jun 11, 2013 10:53 PM
Fozy
Mar 28, 2011 07:42 PM
mikesz
May 29, 2008 11:06 AM
Cw2435
Jan 18, 2004 05:29 AM
280zdriver_16
Jan 9, 2004 10:39 AM
