Big Brake Conversion
Old 12-20-2003 | 08:07 PM
theramz's Avatar
I have a present for you...
Did you rebuild the calipers? If they're dried out they won't work right. The later Zs used a "15/16" master cylinder, the number is right on the casting. The early Z is "7/8". I got mine off an '82 but I think they started in '79. It bolts right in. I used '92 calipers which I took off the truck myself and didn't need rebuilding. The later booster is noticably larger and looks to be a direct bolt in also though I didn't use it. This might sound like a dumb question but I hope your not trying to squeeze the stock rotors are you?
You need the '84 vented, non turbo rotors with adapters.
Old 12-21-2003 | 09:04 PM
theramz's Avatar
Caution, my friend! Here is a picture of some **** someone is trying to pass off as a brake up-grade on eBay. Just bolting on something because it "fits on" doesn't mean it will work! The calipers should almost always be rebuilt. The rotor must be the correct diameter and "hat depth" to centralize between the pads. I'm not sure about the '84 Toyota calipers but I'm pretty sure the rotors should be thicker than the stock Z ones. Another detail is the '70-'71 hubs have a thinner flange thickness (2 mm) than the '72 and later.
Old 12-21-2003 | 09:06 PM
theramz's Avatar
NFG
Old 01-15-2004 | 04:13 PM
theramz's Avatar
I used hubs off a 73' which required a 17mm spacer for the 84' rotors with the 92' toyota 4x4 truck calipers. I also swapped the rears with 82' disc. I figured the 82' had the 15/16 master so I put it on too. So far I haven't tried a panic stop so I don't know if I will need an ajustable proportioning valve. All the bleeder valves must be on top to bleed correctly!
Old 08-19-2004 | 06:12 AM
PROJECTSBZ's Avatar
Originally Posted by ZR8ED
make sure the bleeder nipple is facing down.....
I THOUGHT BLEEDERS ALWAYS GO UP TO BLEED THE AIR OUT OF THE SYSTEM, NOT JUST FLUID? AT LEAST THATS HOW I WAS TOUGHT.
Old 08-19-2004 | 07:54 AM
theramz's Avatar
Bleeder valves on top!!!Brake fluid is heavier than air, it fills the chambers and the air goes up and out. just look at any stock system. If this wasn't true, then when you drain your engine oil, air would come out first!
hchase17
05-20-2009 10:12 PM
Unknown898
06-05-2008 08:33 PM
AllmyZs
07-29-2002 03:59 PM
zealous
05-23-2002 05:16 PM
Skaitan
10-24-2001 10:31 PM
Quick Reply: Big Brake Conversion
