need help with floorboards and rear deck
Old 12-11-2004 | 08:44 PM
chickenwafer's Avatar
Lightbulb need help with floorboards and rear deck
Hey guys. As you can tell, I'm new here, but not to Z cars. I have been surrounded by them my entire life.
Anyways, I have a '74 260z and the floorboards look pretty rusted. Does anyone know where I can get automotive-qualitly or rust-resistant metal to weld in-place of the current floorboards or if anyone makes a pre-stamped floorboard direct replacement? Thanks.
Another problem- my rear trunk deck lid doesn't open- I assume the lock is broken. How do I go about getting to the lock- I can't see how. Of course it doesn't help i'm a freaken ogre and I can't squeeze back there to gain much access to the lock, but any tips would be greatly appreciated. Thanks in advance.
Dave
Old 12-12-2004 | 10:59 AM
e_racer1999's Avatar
Zedd Findings
Old 12-12-2004 | 11:17 AM
thanks a lot; you're a life saver
Dave
Old 12-14-2004 | 09:29 PM
myxtaz's Avatar
I agree , I have installed one of his floors and they are first quality. To get at the latch on the rear hatch . You will need to remove the pannel that coverers the area just below the glass. This will expose the latch assembly.
Old 12-15-2004 | 07:47 PM
RWilliKiwi's Avatar
floorboards
Dave,
"Does anyone know where I can get automotive-qualitly or rust-resistant metal to weld in-place of the current floorboards or if anyone makes a pre-stamped floorboard direct replacement?"
I just saw an ad in Sport Z Magazine today but they are not cheap.
http://www.datsunzparts.com/Summary.htm
"Another problem- my rear trunk deck lid doesn't open- I assume the lock is broken. How do I go about getting to the lock- I can't see how."
Try turning the whole lock by hand. If it turns the mechanism has come adrift inside. That's the bad part but the good part is if you turn it enough you can either get it to line up or remove it through the hole.
Good luck
Ross
Old 12-18-2004 | 12:30 AM
myxtaz's Avatar
Originally Posted by RWilliKiwi
Dave,
Good luck
Ross
Zed findings makes the best replacement floors there are cheeper but you get what you pay for. I have installed a Zed floor on one side of my 240 and it is first rate. POR-15 I have used as well to protect any surface rust and bare metal. Rust Bullet is another that is supposed to be as good but easier to use , I question the lack of preperation issue with this paint. POR goes a vary vary long way so dont buy more than a qt. at a time. Important to use the preperation that is required other wise the paint will peal off. If done correctly it is permanint and a vary hard but flexabile surface that acetone wont even touch.
Old 12-18-2004 | 03:05 PM
thanks for all the input- i can't wait to get my Z rust free
Mar48
01-18-2012 05:40 PM
dankfrye@charte
07-19-2011 01:24 PM
dankfrye@charte
06-24-2011 11:08 PM
Daeron
10-27-2004 05:53 PM
chukker
09-06-2002 02:54 PM
