Wheel size...
Wheel size...
What looks good on a Z?
I know that is a matter of opinion. Some like to see plenty of rubber, some like rubber bands. I won't say anything, but I would like to see a thread on the forum with wheels, and all the different size combos we can find.
So, let's see them.
So, let's see them.
16-15's are teh best imo just because you keep a more classic look, but still have a shorter tire height for less sidewall flex. here are mine though. 14's unfortunatly
they wouldnt be so bad if i lowered the car, which by X-mas time i should have well done with paint on the way. carparts for X-mas is the bestest ever. new struts springs sway bars my own engine hoist more under body coating and enough paint hopefully and clear for both my Z's so i can up the price on the 260 unless its gone by then.
Originally Posted by theramz
I like my 17s on Toyo Proxies. 215 on front and now 245 on the rear.
Hmmm.. Like the wheels, but I can't tell what they look like on the cars guys.
All I see is wheel. No point of reference with the rest of the vehicle, to prove that it's size fits well with the car.
you have adapters from modern? ^^^^ so you can run honduh lug pattern
FIRST OFF... The S-30 hubs are LUG CENTRIC not HUB CENTRIC. Your couterbore is nice but THERE IS NO ACCESSABLE HUB PROTRUSION ON THE BACK HUBS.
It is not as much about the "LOOKS" of the wheels as how they work with the suspension modifications you experts are attempting.
The smaller the wheel the better! SMALLER IS LIGHTER, SMALLER HAS LESS ANGULAR MOMENTUM, SMALLER HAS LESS FLEX.
There are a lot of reasons for buying larger wheels. None of you has clued into WHY!!!
I'm pretty sure that a larger alunimum wheel will be MUCH lighter than a small STEEL wheel. That a smaller wheel with a huge tire on it with a massively tall sidewall will FLEX more. Don't throw out such nonsense without explaining. I'd hope you'd have a reason behind all of this other than to just taunt us about what we do and don't know.
Everything else being equal, smaller is lighter. Tis a function of scale. I made no mention of materials or design. There are very light steel wheels and there are very heavy aluminum wheels. This is not an argument, It is fact.
Here are a few reasons for larger wheels. Lowered car, bumpsteer is out of whack...
sectioned struts,
Lower control arms are already repositioned,
all control arms are modified,
Can't raise the rack,
The answer lies in repositioning the steering tie rods to correct bump steer,
This mod will require 17" wheels.
Which sucks, because I have a nice set of 15"x10" lightweights I can't use.
I also had to reposition the differential to make this work.
sectioned struts,
I like the larger diameter tire with the larger wheel because the narrow sidewall has less flex. The larger wheel allows for wider tires that can clear the brakes and the suspension. They work great for the type of driving that I do. I also like the looks.
For autocross like you do, the lighter wheel and tire is best. And they look great on a real race car.
There is nothing sticking out of the rear hub to engage the spacers, unless you have figured out how to mount the rear disks on the back of the rear hubs.
So, let's see them.
So, let's see them.
So, let's see them.
So, let's see them.
MellowYellow300
17
01-30-2007 06:56 AM
