Lowering springs didn't lower my car!
OK whats the deal. I put my new Eibach springs and new struts on the z and it doesnt look any different than before the swap. WHY ISNT MY Z LOWER???
nismo, mine seems to be the opposite. I see a slight lowering in the rear, but the front looks high, at least as high as before. do you think the new strut cartridges have anything to do with the height?
I've got a pic in my Garage photos.
i think your car was already lowered to start with, it looks like it at least, measure from the center of the wheel to the lip of the fender, everybody else do the same on there s30 and we'll see what it comes up with. or if you got a fsm, it gives measurements to the bumper height, use that as a guide, if there is no diff. between old and new (including stiffness) then return the springs and buy something needed more
I don't get it... I've got tons of pics of S30's and I've got more space under the fenders than just about all of them. I'm running on 60 series tires on 14" rims. Bigger tires or bigger rims would raise my car, wouldn't it?
If I can't figure it out, I may resort to chopping a piece of my springs off to lower it!
If you needed a spring compressor to get them on then they are not lowering springs. The correct struts are also shorter. The front springs should also be slightly shorter than the fronts. I put the whole set on my car and it lowered it about an inch with a slight rake. A much stiffer ride but greater control than I expected.
One possibility, drlew:
stock on '78 280Z's was 195/70-14 (according to TireRack, my FSM CD ROM is at home today...) http://www.tirerack.com/tires/Select...8&autoModClar=
I'm pretty sure that's correct. If your width is the same (first number of the tire size), then your 60 series (aspect ratio, second number) sidewall would be shorter than stock. Because the last number is the same (wheel diameter), then what you'd have is an overall shorter (smaller diameter) wheel/tire combo. That would both simultaneously lower the car, and increase wheel gap from stock specs. You can get some variation by what exact width you're using, inflation pressure, sidewall stiffness (varying across models, brands, or even production runs), etc. But those changes shouldn't amount to a whole lot, total.
I used Tokico springs, and it noticeably lowered my car. As theramz mentioned, aftermarket, lower springs won't need spring compressors for installation (hooray, you don't ruin the nice powedercoat finish). My original springs were definitely original, definitely sagging, and still were higher than the Tokicos. However, pictures and numbers from my car are still worthless because there's no engine, tranny, seats, or dash in it yet, so the loading is all way off and goofy looking.
Dave
Dave
I bought the Eibach Spring Kit at Motorsport during the MSA show, because I liked how almost everyone elses cars looked lowered. Then, before I put them on, I decided to also order struts (Motorsport recommended Tokico HR cartridges - non adjustable). I had them put on all at the same time.
I know, this is what I get for not doing it myself... For all I know, he could have put the fronts on the back and visa versa.
i lowered my 77 with the eibach kit and i realy noticed a difference i think that shady is right it may have been already lowered. if you need shocks let me know..
here are some monthly specials for you.....
Dear Z car lovers and drivers.
Us here at Motorsports Direct would like to offer you guys a great deal on some products that we have to offer.
Everything is in stock, and if not we can still order it for you. As long as you purchase before the end of Feb. you Z guys get the special price….
To order just call
Anthony
anthony@motorsportsdirect.com
1-800-245-1001ph
702-245-1001 Canada
THIS IS ONLY FOR THE MONTH OF FEBUARY!!!!
SUSPENSION
Tokico suspension
Tokico Hp Shocks “blue”
$197.00 ALL S30 Z’s 1970-1983 (including zx model)
free shipping
Tokico Illumina Shocks “adjustable”
$382.00 ALL S30 Z’s 1970-1978
free shipping
Suspension Kits
Hp series kits (HP non adjustable blue shocks and springs 1” drop)
$322 + $12 shipping for 1970-1974 ½ hpk251
$345 + $12 shipping for 1974-1978 ½ hpk253
$322 + $12 shipping for 1979-1983 hpk255
Ilk Series kits (Illumina adjustable kits and springs 1” drop)
$470.00 ALL S30 Z’s 1970-1978 ilk252 & ilk254
FREE SHIPPING!!!!!!!!!!!!!!!
Koni Suspension
$500 + $10 shipping 1970-1975 240z 260z
Ground Control
$330.00 + $10 shipping 1974-1978
Russell Brake Lines
$82.50 1970-1983 686550 , 686600
ACT Clutches
$390 1974-1983 225mm non 2+2 & turbo
$280 1979-1983 240mm including 2+2 and turbo
FREE SHIPPING!!!
EVEN TO HAWAII, GUAM, CANADA OR PR!!!!!!
To order just call
Anthony
1-800-245-1001ph
702-245-1001 Canada
SUSPENSION
Tokico suspension
free shipping
free shipping
Suspension Kits
Koni Suspension
Ground Control
Russell Brake Lines
ACT Clutches
FREE SHIPPING!!!
^^^ um... could ya be any more annoying with your advertising?
Right now, I wouldn't buy anything from you just based on principle and the fact that your adds are pissing me off
Rod.
