stuck trying to remove rear strut :(
Old 06-25-2012 | 05:38 PM
DerekkAllenn's Avatar
Unhappy stuck trying to remove rear strut :(
Hey, removing my rear strut on my 78 280z
It says to remove the spindle in the service manual but i cant get the center bolt out to do that any tips?
does it have a preload point or something cause that ****er wont budge >.<
Old 06-26-2012 | 06:39 AM
turbopuppy's Avatar
There is a retaining bolt. After removing the retainer, you have to nudge it back and forth with a drift and a hammer from both sides until you can pull it. Hit it with penetrator and allow to sit for several hours. See
http://atlanticz.ca/zclub/techtips/s...uts/index.html
Have fun and don't let it get to you
Old 06-27-2012 | 05:01 PM
theramz's Avatar
I have a present for you...
Are you asking about the stub axle or the spindle pin and lock pin?
Motorsport! Spindle Pin Lock Bolt, 70-78 240Z-260Z-280Z - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
Old 06-27-2012 | 06:12 PM
its the spindle pin and lock pin im pretty sure.
Old 06-28-2012 | 11:04 AM
theramz's Avatar
That taper lock pin is rusted in there. Soak everything with a good penetrant. Back the nut on the lock pin out one turn or just past the threads to protect them from the hammer. Tap it gently to see if it loosens up. Spray it again. I made a spindle pin punch with the threads in the end so I wouldn't destroy it. If you can't do this the parts won't be reusable so buy new ones.
PredatorZ
03-19-2014 12:04 AM
mikeatrpi
08-27-2012 07:59 AM
Photoguy360
11-21-2011 03:22 PM
Comrade_Charlie
09-07-2006 05:51 PM
zpeedrazer
12-08-2001 05:46 PM
