280Z Engine Swap
280Z Engine Swap
I have an 1978 280Z, L28 and I would like to swap engines with an engine that will fit directly in the engine mounts. I was looking for options available to me. I was told that I 300ZX engine would bolt right in.
Any advise on swapping engines would be appreciated.
and don't take any advice from the moron that said you could drop a VG30 into your car with no modification. You can swap in a maf and ecu from a z31 and get improved performance for your L6. Best bet find a turbo car for cheap and take that engine and wiring harness. alternately the 82-83 n/a engines are probably the best of the series.
I'm actually in the middle of this engine swap and in need of help. I purchased a 1976 280z with a 1983 280zx, not wired https://www.zdriver.com/forums/240z-260z-280z-motor-swaps-non-v8-269/transplant-zx-z-32516/. It has the 1976 harness with the 1983 efi harness. I managed to run power to the ecu and other components. The car turns and all but doesnt want to give in all the way. I'm pretty sure its because it's not getting power on ALL the components that is needed for the engine to fire. If anyone can please advise or point me to a direction where I can find source on this swap, it will be greatly appreciated. Thanks guys.
smcclure776
04-03-2015 01:51 PM
mbgnh1
01-20-2013 06:58 PM
smokingzcar
12-05-2002 07:57 AM
