81 turbo swap question
hey guys,
I know I should have no questions when it comes to swapping a turbo motor into an S30 chassis since i have done it 3 times now but I'm doing a 4th and this time its my first 81. After wiring in the harness I realized other than the ECU and dropping resistors and ever so slight changes in the non ecu plugs on the harness its pretty much the same thing. I actually didn't even realize it was an 81 and just wired from memory then I was like oh crap this is an 81 popped out the write up for it and saw I only had to add one extra constant power and instead of having a start" signal I use a switched power" signal in place. Otherwise the exact same thing. Now here is my problem. The ecu I got sent with it didnt power up. LED never lit up. Said ok well ECU is possibly burnt out. Got another one sent to me... same problem. So now I'm going over my grounds and go hmmmm.... So i grab my 82-83 ecu plug it in, it powers on. Now, I didn't hunt down the exact differences in the harness years but would you all make the same assumption I am, that if I can power on an 82-83 ECU off an 81 harness wired as per the write-up on hybridz
aka: A quick FI and ignition 280zxt to S30 turbo swap guide - HybridZ
that I yet again have another crap ECU or is there some 81 turbo trick I'm oblivious to... I'm getting a bit frustrated haha.
Thanks hoov. But this actually is not my project I'm doing this swap for mike and have everything done except getting the car to run due to the lack of powering up of the ecu. And I've never done the z31 swap so I wouldn't make mikes car my guinea pig. Ok folks maybe my question isn't concise enough. Assuming the swap I posted is 100% correct and I did the wiring correct. But the 81 turbo ecu's led won't come on when I turn the ignition on yet when I plug an 82-83 turbo ecu in and its led does light up would that presumably mean my wiring is correct and i have two **** 81 ecu's or is there something I could possibly be overlooking.
I compared the 81T ecu schematic to the 83T, and THE ONLY differences are:
-ECU pin#6 = Fuel Pump Control Module (81T doesn't have it, 82-83T does)
-ECU pin#114 = +12V unswitched power (81T doesn't have it, 82-83T does)
The only difference would be that the 81T ecu sends a high impedance injector signal thus needing the dropping resistors vs 82-83T ecu already programmed for low impedance. If the 82-83T ecu lights up, I would just make jumpers to delete the drop resistors and plug in the 82-83T ecu.
I knew the plug was the same. just figured since one is magnetic signal the other optical they would have different outputs. I see that's not true. I do see there are two turbo afm's though so any idea if there's a difference in those. or is it just jumper n done.
81 harness has the dropping resistor in the harness like 1.5 ft down the line from the ecu. I found the 81 cas covered in paint the ecu would never power and the jumper idea was so so. So instead I got an 82 harness dizzy oil pump shaft and ecu and then the motor seized. Pulled it apart did a full rebuild found a washer in 4 pieces in cylinder 2 causing the engine to jam. Put back in runs perfect but turbo won't create any boost.
MurphyEF
10-04-2012 09:24 PM
johnsonsz31tt
05-07-2008 08:27 PM
