240Z, 260Z, 280Z Motor Swaps (non-V8) L28ET RB SR KA VG VQ 2JZ etc....
need help on my N42 block and head
Old 01-07-2011 | 06:39 PM
Datsky's Avatar
i purchased a 72 z come with a rebuild engine. i recently discovered it is a n42 block with E80 HEAD w/stock cam. my z buddy suggest that im running about 9:1 CR, and it will be running even better with n42 head. lucky i picked up the n42 head from 75 z at the pick a part. right after i removed the head off the engine, i found the 75 N42 block has flat pistons. and then i started to get confused. because my buddy also suggest my 72 z runs on flat top pistons. but not sure of. anyway. didnt any1 run oem N42/N42 w/flat piston combo? and how is the compression ratio on it? thx
Old 02-06-2011 | 08:54 AM
texasz's Avatar
Best thing would be for you to go download the L Series Engine Calculator from this location: http://www.zcarcreations.com/downloads.htm
Festus Portnoy
06-22-2015 04:04 PM
TwoEightyOwens
11-19-2013 01:05 PM
TonyD11
05-30-2007 07:35 PM
DoTheDrew888
03-23-2005 10:49 PM
