1972 z problem "help" please
my z been sitting in out for a good 5 years. it was running before, so now it's not. the fuel have been dried out.
Thing's i recently done to the car. I swap out the L24 to a L26.
I have sparks, but no fuel pressure. Anyone can lead me in the right dirrection?
Also, can someone post up a picture or diagram of the spark plug wires goin to the dizzy.
I need the timing degree as well.
Clean the fuel system 1st
I would suggest pulling your tank and having it cleaned and most likely sealed / coated. You might need to fill the tank completely full to get the Pump to prime. Your fuel lines could be fouled with old gas glaze. Radiator shops can clean your tank for you.
Now, let's get back to the original post.
1. Are you working with fresh fuel?
2. Will the car start if you use starting fluid?
3. Have you determined how far the fuel has travelled between the tank and the carburetors?
4. Did you clean out the carburetors before trying to start? There could be lots of varnish in them.
yes its carburater. i have bought a new fuel pump, and i still dont get any fuel AT ALL. i dont know what is wrong. at first i thought it was the fuel pump but now i eliminated that. what can it be? and NO i didnt clean the carb, but i dont think that could be the problem that im not getting NO FUEL.
Well, let's start from the tank and work forward.
1. Does your tank have rust in it? That can clog the pickup.
2. Does your car have an electric fuel pump? (Yes, even some 72s have electric fuel pumps.) If you do, it is mounted at the gas tank. It probably has a filter between it and the gas tank, too. To see this, jack up the right rear tire and take it off. There is an access panel in the back part of the wheel well held on by some Phillips-head screws. Once you remove this panel, you'll see the right front of the gas tank. There you will either see some fuel lines going from the tank to the engine bay, or you will see a small electric pump. Ensure that there is not a clogged filter back there.
3. Check the fuel filter in the engine bay. Does it have gas it in? Have you changed it since you owned the car? They are cheap.
4. If 1 through 3 are good, then locate the fuel line between the mechanical fuel pump and the fuel rail. Disconnect the end that goes to the fuel rail and put it in a gas can. Have someone crank the motor while you look to see if there is gas flowing. Reconnect the fuel line when you're done.
5. Check the carburetors. See if the bowls have fuel. If 1 to 4 checked good and the bowls are empty, carefully put a little gas into them and close them up. Try staring the car. If it does start, try some starting fluid. Does it start then?
My car does not have an electric fuel pump, only mechanical fuel pump,
What i've try for the car so far:
1. bought a new mechanical fuel pump
2. clean the fuel hoes from the fuel filter to the gas tank. Can feel air going thru freely.
3. bypass the fuel filter, and just prime fuel directly to the mechanical fuel pump.
4. spray brake cleaner in the carbs.
Somehow there's no pressure takin the fuel. Anyone can lead me from here. really need help.
## what i'm gonna do:
1. take off the gas tank and check if it's clog in the tank.
2. check the fuse
2. check the fuse
Okay quick update. The gas tank is freely unclog. The fuel line are free as well.
I took off the fuel line while someone is cranking the car to see if there is air sucking the fuel out of the fuel tank, and I notice that there's only a tiny small amount of air pressure.
So there isn't enough air pressure to suck the fuel from tank to filter to the engine.
How much fuel is in the tank? You sure the pick-up line is submerged enough to grab fuel? Is the car on a ramp / jack stands?
Have you removed the fuel pump to manually push the lever by hand to see if it will pump / create vacuum?
Might want to pull the cam cover to make sure the cam lobe is actually touching the fuel pump lever.
i have about 3-4 gallons in the tank, the car is on the lift. does anyone have a fuel regulater?? i got a electric fuel pump, but seems like once i plug it to the battery, the pump turns on and fuel comes thru but the car wont start and then fuel starts to flow out from the carb. any suggestions, ideas?? please comment/help
Well, is it a high pressure (fuel injection) electric pump, or low pressure (carb) pump? As previously stated, these carbs only need 3-5psi fuel pressure.
Did you pull the mechanical pump / timing cover like I said?
yes the cam lobe is touching the pump lever. i got the electric pump from one of my brother's friend, and he says he pulled the electric pump off his 240z, said it was working and the pump was mainly for carb z. so for sure its low pressure. probably only 4-5 psi
If you are settled on using an electric fuel pump, here is how you can wire it safely, provided you still have the externally regulated alternator.
1. Tap into the yellow wire coming off of the alternator and run it to a relay pin 86.
2. Run pin 85 to ground.
3. Run power from the black white wire to a fuse and then to pin 87.
4. Run pin 30 to the positive on the fuel pump.
5. Run the negative from the fuel pump to ground.
The yellow wire should only have voltage when the car is alternator is turning. The black/white wire only has voltage when the key is in the ON position. This should prevent the fuel pump from running if the engine isn't turning.
As for a fuel pump, look for one for a carburetted RX-7. That should be a low pressure pump. You can see the years at Blackdragon Auto and price shop against Amazon and RockAuto.
TheShanMan
03-08-2014 04:25 PM
rickyyea
14
03-05-2012 07:19 PM
Lev
09-19-2009 01:35 PM
PowerhungryBill
09-16-2008 10:04 AM
