240 Slave cylinder
Old 09-05-2005 | 02:10 PM
BoKnows's Avatar
240 Slave cylinder
Has anyone heard of blowing the seals on the slave cylinder after putting in a new clutch? I have been through three. It seems that the travel on the push rod is too long and just pulls the boot off. Someone said this could happen (rarely) after shaving the flywheel, but it seems a new clutch disc would create slightly less travel if anything. This is on a '73 240.
Old 09-05-2005 | 09:03 PM
theramz's Avatar
I have a present for you...
It could be the clutch pedal adjustment. Make sure you have about 1/2 of free travel. If you don't, then it will push the slave piston to far.
MitchG05
05-04-2014 06:46 PM
mjz
03-01-2012 06:41 PM
rednismo1984
02-02-2006 03:06 PM
jbaran1123
11-20-2002 10:46 AM
Quick Reply: 240 Slave cylinder
