260z problems
260z problems
I have an early 74 260z. I just replaced the starter and now none of the electrical equipment will work. The car will not turn over. I hooked all of the cables back up correctly and checked the battery. I can stick a screwdriver in between the 2 post of the starter and the car can crank up and the electrical equipment will work. Does anybody have any clue of whats wrong?
Thanks
Thanks
Thanks
Thanks
It could be a defective (new) solinoid. Could be the terminal ends a broken off but the covers are still in tact. What you are doing with the screw driver is bypassing the ignition switch.
2sixtyz
06-19-2011 06:50 PM
LCPLM260z
04-25-2011 12:30 PM
RMW260Z
08-01-2005 12:46 AM
