280z fusible link question...
Old 05-21-2011 | 09:57 PM
greenzee's Avatar
Generally, could we use a bigger wire gauge as fusible link to replace a tired one? I have used one but the other 3 are originals. Just want to have all four with uniform size wire. Appreciate any comments.
Old 11-10-2011 | 10:38 PM
90turbo1's Avatar
from what I have been told the fuesable link is very similar to a set of leads for your multimeter, they are not constructed the same as a simple wire. Finding the correct wire diameter and such so it burns at that specific amperage (what the fusable link was designed to do) would be very hard. Have you thought about just getting rid of the fusable links? swapping them out for a fuse holder?
just my thoughts on this..
Old 11-11-2011 | 09:37 PM
x2.
Don't waste your time, just replace them with reliable fuses:
http://www.atlanticz.ca/zclub/techti...nks/index.html
Pink 30 amp
Green 40 amps 0.50mm˛
Red 50 amps 0.69mm˛
Yellow 60 amps
Black 80 amps 1.25mm˛
Blue 100 amps
Note: Fusible links are designed to melt and not catch fire. Regular wires can catch fire. Do not substitute!
http://www.hammondsplains.com/s30upg...fuse/index.htm
Old 10-12-2012 | 01:10 PM
zcargirl's Avatar
83zx NT - Fusible Link
Do you have a guide like this for a 83 280zx Non Turbo?
Than You!
Old 10-19-2012 | 12:34 PM
zcargirl's Avatar
Fusible Link
I have replaced the ECU and the car is running now, or I should say, it starts and will run. However, I had to attach a wire to the fuel pump, with a switch....it's not engaging otherwise, and it is running rough and smoking.
Nismo, It was your answer to previous threads that has led me to good solutions, so far.... I think I remember another member who ran into this and I will check his thread. But if you have any next steps for me, I would appreciate it. I'm not a mechanic, just a girl who digs her car and likes to solve problems and do the work herself, if it is not labor or technically intensive. The ECU was easy....just plugged it in and saved $1000 in mechanic fees So grateful for this site! Would have needed a mechanic to figue it out otherwise. Thanks Ya!
Old 10-20-2012 | 09:04 PM
That's just a fancy kit that keeps things organized and looking good. You could just replace your fusible links with normal fuses of proper rating, by cutting the wires below the box, crimping on female spade connectors, electrical tape, and zip tie them together to keep them tidy.
Check the green fuel pump relay if the fuel pump won't prime / run on it's own.
Old 11-11-2012 | 08:26 PM
Steve260Z74's Avatar
One word of warning concerning the maxi fuse conversion. I've talked with the person who posted it. I'm not sure the fuse ratings are the same as the fusible link ratings.
On the other hand, proper fusible links are still available from Courtesy Nissan and NissanParts.cc.
Old 11-11-2012 | 08:36 PM
Use proper blade fuses in place of OEM fusible links... Simple as that.
Pink 30 amp
Red 50 amps 0.69mm˛
Yellow 60 amps
Blue 100 amps
ol55
11-27-2013 01:11 PM
DRH13
08-20-2013 09:07 AM
DarrellBuddy321
03-10-2006 03:54 PM
Sion
09-27-2002 09:08 AM
