6 speed trans
Old 08-26-2012 | 06:37 PM
baker87's Avatar
6 speed trans
are there any 6 speeds that will work in the 240z? and how different is bellhousing?
Old 08-26-2012 | 07:30 PM
A quick search for "6speed" will give you the answer.
A good read: https://www.zdriver.com/forums/300zx...ns-swap-32281/
Things you should consider first:
-The 6speed will have different gear ratios.
-The 6speed will have different bell housing.
-The 6speed will have different size specs which will make fitting a biotch.
-The 6speed will have different output splines, so custom drive shaft needed.
And after all that, unless you daily drive on a rural freeway that has 80mph+ speed limits, you'll never need 6th gear.
But alas, if you have tons of money, and awesome fab skills, get to it!
PooFlinginMonke
06-01-2011 10:58 AM
300ZXLS6
FS: 300ZX (90-96)
05-27-2009 12:15 PM
two80ztom
04-21-2009 10:15 AM
CWHammer
08-27-2005 07:03 PM
