Blow off valve hook up?
Old 11-26-2003 | 07:33 PM
veyenyl's Avatar
Tee off any vacuum line from the intake manifold.
Old 12-01-2003 | 10:13 PM
zguy36's Avatar
Dead
You should be able to see the BOV open when vacuum is applied to it. You don' have to rev the motor, as the diaphram only opens when there is vacuum in the manifold. If it isnt' opening, then there is something wrong with your valve, probably a torn diaphram. You might not be hearing the "noise" since there might not be enough boost for it to vent off. Just a thought on the last thing.
-jeremy-
hchase17
03-16-2009 07:46 PM
pearly whites
10-31-2003 10:52 AM
haktmal
04-20-2003 06:59 PM
Monkeyboy
11-05-2002 02:56 PM
lil_racer_tony
08-27-2002 11:19 PM
Quick Reply: Blow off valve hook up?
