Boring Intake
Old 02-26-2012 | 02:12 PM
76 2+2's Avatar
Boring Intake
From what I understand the l28 intake is very restrictive so is it possible to bore out my intake at home? If so where do I start, where the throttle body attaches, where the intake and head meet, or both? And will a ka24 throttle body fit a s30? I want a little more power and this seems like the only options on my budget which is very very small. Thank you for help in advance..
Old 02-26-2012 | 05:19 PM
https://www.zdriver.com/forums/280zx-s130-forums-77/my-turbo-plenum-32430/
https://www.zdriver.com/forums/280zx-s130-forums-77/240sx-throttle-body-hook-up-29240/
look for an Altima KA24DE motor, or Infiniti G20 SR20DE motor. Those are 60mm as well & usually use a linkage ball. Then all you have to do is cut that spring dowel & flip the linkage ball.
Old 02-27-2012 | 03:25 PM
76 2+2's Avatar
Thank you for the info, I looked at the links but am still a bit confused. What is a prenum? Is there a specific line that I need to cut on? Are the runners the 6 pipes that meet the head? And should I pull an intake manifold off a junkyard z for practice? Thank you again
Old 02-27-2012 | 08:52 PM
It's a "plenum". The plenum collects the air from the throttle body, and directs it to the intake runners / cylinder head intake ports.
Unless you are a hardcore experienced machinist / TIG welder (doesn't sound like it from the question), I suggest leaving the plenum and intake runners alone, and just bore the intake neck for the 60mm throttle body.
Old 02-29-2012 | 02:52 PM
76 2+2's Avatar
Hit the nail on the head i am inexpirienced haha and thank you for your help, also n42 intake good?
Old 02-29-2012 | 05:03 PM
"Good" in what way? There's no real advantage other than no webbing.
Old 03-04-2012 | 01:38 PM
76 2+2's Avatar
Ok cool so nothing extra special about it other than lack of webbing? And no webbing means less restriction? Thank you again
Old 03-04-2012 | 02:06 PM
evandubya's Avatar
Primer Grey FTW!
The webbing is on the outside, between the runners.
Old 03-04-2012 | 09:39 PM
76 2+2's Avatar
Oh thank you im not exactly the sharpest tool in the shed
Old 03-04-2012 | 10:19 PM
evandubya's Avatar
Primer Grey FTW!
You're ok, just start using the search more.
Old 03-05-2012 | 03:09 PM
76 2+2's Avatar
I feel even duller neglecting the search feature haha thank you a lot
Niku-Sama
10-22-2009 02:55 AM
thetremendousti
09-24-2009 04:30 PM
91Zman
04-15-2006 10:56 PM
280ZX_AV8R
06-17-2005 07:47 PM
thomas schuchat
04-17-2003 12:26 PM
