High Rpm question
High Rpm question
I done some research and could not find the right answer. I have 71z with l24 block, e88 head, elec ignition, and type b tranny. I had mechanic that work on Z's do an inspection to the car and make minor adjustment like the timing and valves. The car idle and runs fine until i hit 4k rpm's. Car shakes and rides rough peakes out at 5k rpm's. I look at the tach and it indicates 6500rpms. Has anyone had this problem before and what they have done to fix the problem.
Originally Posted by 1971z
I done some research and could not find the right answer. I have 71z with l24 block, e88 head, elec ignition, and type b tranny. I had mechanic that work on Z's do an inspection to the car and make minor adjustment like the timming and valves. The car idle and runs fine until i hit 4k rpm's. Car shakes and rides rough peakes out at 5k rpm's. I look at the tach and it indicates 6500rpms. Has anyone had this problem before and what they have done to fix the problem.
Besides that, the Z is rated for 150hp at 6000 rpms. That means that anything over 6300 or so is going to start some valve float, so you don't want to go too far over 6000. The Z will actually slow down after 6300 or so, because it can't accurately make power at that high of rpms. I just got done rebuilding my Z ( I have an L24 block with an E88 head, Pertronix Electronic Points condenser system, stock exhaust headers with glasspack, no cat) and it pulls hard up to 5k. I haven't gone too far over that, because the motor only has 20 miles or so on it. Try taking a timing light to your Z to make sure that your mechanic did the job right, and try checking your plug wires and make sure that your plugs are all firing.
Another idea may be to check out your plugs,may need a change. Also how are the carbs condition wise. Are they in tune? You may be running rich (black smoke out of the exhaust, black sooty plugs). The carbs may need to be adjusted for air/fuel and synched.
unless you know what you're doing, I wouldn't adjust them. Most shops will tuns your carbs, set your timing regap your plugs and everything else for only an hour of work. As long as your air fuel mixture is right, then all you have to do is get a carb sync tool, called a synchrotester. All you do is put it over the air horn on the front carburetor, and get the float ball to stay at about middle at idle, and then check your rear carburetor to make sure it stays at middle. To adjust, use the screws on the side of the carburetor. You can get a sychrotester from motorsportauto.com, but they tend to rip you off with prices, I've seen them for as cheap as $12.00 at harbor freight.
Check the color of your spark, should be blue not red or yellow=bad coil. Check your vacuum advance. You may have a weak ground and connections on the distributor. This will cause the tach to bounce around too.
2nd on what fast240z said, don't mess with the A/F too much if you don't really know what you're doing. A lot of that either requires a colortune or just some experience. If there's someone who's been around Zs for a while in your area, they could prolly walk it through with you.
I believed i gapped the spark plugs at .034 or .035
I checked the spark plugs and they're black with some brown on it. I did not see any of those colors you had mentioned. By some chance did they ever match the yr and the month of the car to the black coil. If they did it says 12 -93182 being that another person put a used part not matching the car. Also its old and might need to be replace. The part is not expensive and i will not feel bad if thats not the case. I have the autolite 7.5mm ignition wires, bosch platinum +2, and gapped at .035. Any other suggestion or should i go ahead and buy a new coil.
Thanks
Thanks
Thanks
Thanks
I'm not sure but I think the Pertronic still needs a condenser on the distributor for the tach to work right. If the distributor shaft is worn out, it will push away from the pick-up. Check the side play. Good idea on the hotter coil.
