I hate Green Z's and Ham!
I will not drive them in a house and will not drive them with a mouse.
Ok, so now I'm being told that my AFM is bad, do we agree or disagree?
(Refer to "on goin problems" post)
The AFM or MAF senses air temp/density. All it is, is a hot wire that reads resistance changes in the temperature of the wire. I don't think it would make your car run rich like that. If it is burned out then it will tell the ECU that it is stone cold air passing throuh it which may be causing the erratic idle. If it tested bad then you have to replace it anyway. Let us know what happens..
The thinking is that it is malfunctioning and opening and closing at the wrong times, therefore causing the mis/backfires as well as erratic idle and all the rest, we'll see. What's another $200 to find a cure?
Good luck and happy hunting!
I got smart and pulled the air cleaner off, while leaving the AFM connected, and it sounds like it is not opening and closing correctly, at best the car sounds like it has asthma. Throttle it up and you can hear the valve plate inside popping shut. So we're replacing the whole unit for about $100 from Z Car Atlanta.
