Ignition Coil Condenser...Important?
Old 08-06-2007 | 06:10 AM
Spurs212095's Avatar
I removed the ignition coil condenser from a 1977 280z (the rf condenser that is mounted beside the coil and grounds to the air mass meter bracket plate) because it was preventing the car from starting? Anyway, the car starts but runs a little rough and I wanted to know if anyone could tell me if this grounded condenser affects the engine performance. A parts man told me that it was an RF (radio frequency) condenser and only affected the radio by preventing buzz when the car was running, however I wanted to check with anyone who drives a Z and might know more. Best, 77 280z
Old 08-06-2007 | 07:57 AM
Correct... for the fuel injected Z's it's just an RF interference condenser. But it should not prevent the car from starting / running. Something else is probably causing the problem.
Old 08-09-2007 | 07:27 AM
Thanks. 77 280z
Old 06-04-2012 | 06:24 PM
jkeese01's Avatar
I had a problem with my alternator condenser. When plugged in, the Ignition Coil Trigger Input Circuit Test, voltage test of pin 1 on harness tested 3.6 volts when it should have tested battery voltage. Car would crank, but would choke when you pressed on the gas.
Unplugged it from the coil and the car would not choke when the engine was rev'ed.
Old 06-05-2012 | 10:50 AM
jkeese01's Avatar
Typo: should be Coil Condenser
Originally Posted by jkeese01
I had a problem with my COIL condenser. When plugged in, the Ignition Coil Trigger Input Circuit Test, voltage test of pin 1 on harness tested 3.6 volts when it should have tested battery voltage. Car would crank, but would choke when you pressed on the gas.
correcting typo
Old 06-05-2012 | 11:02 AM
uber-old thread... Please check-a-da-date before posting.
OP hasn't been online in 5 years.
83Turbo
05-31-2010 10:21 AM
n00blar
06-03-2008 01:26 AM
21Nemesis
12-07-2006 01:13 PM
Aphrodite
12-31-2005 01:19 PM
MetalTear17
08-22-2004 09:46 AM
