Intake Question please read
Ok we all know that the colder the intake air the better because it is denser thus more hp. Now what if You were to take a cold air intake kit that uses pollished aluminumn for piping and wraped thin walled copper tubing around it and plumbed the tubing to your ac compressor thus cooling it like a freezer would this work its only an Idea????? Please let me know what u think
Gidday Hellrazor,
Cooling your air is beneficial, but air flowing thru an aluminium pipe isn't going to affect the temp much. . .think of an intercooler. . they use lots of small pipes, like a radiator, with lots of fins so there is a very big surface area for the air to be cooled against. In the aluminium pipe with the copper pipe coiled around, your surface area isn't very big. . .if you consider the points at which the copper pipe contact the aluminium. The aluminium and copper construction, will also take a lot of heat up from the engine bay, making your a/c work harder, and as ChEng stated, the power to run you a/c is going to be more than the power gain from the cool air. You are better off trying to shield your existing air intake piping, and get the filter out in front of your radiator somewhere, where it can get cool air in.
I take it your car isn't turbo'd???. . . .you could use an intercooler with a water spray. ..an intercooler by itself isn't going to do anything, but spray water on it and the evaporative effect would help.
Cheers - Simon
Cheers - Simon
domsgarage
10-11-2010 08:44 PM
NismoPick
02-22-2009 12:59 PM
NismoPick
02-22-2009 12:58 PM
CaptainZ
10-01-2004 11:18 AM
