l26 with p90 head
Old 12-01-2012 | 08:53 AM
Tooquick260's Avatar
l26 with p90 head
Hi, just recently i found a really good price on a p90 head. Its in my garage and im going to be sending the cam that came with it to schneider so they can regrind it. I've read some very controversial things about shaving the p90 head for the l26 block, so what is the truth? My goal is 9 or more compression ratio. i want to shave it .080 and put a schneider cam in it. will i have enough valve clearance if i do this and what head gasket should i use? im looking at the 260-70 cam, heres the url
260-70F Datsun L-6 Camshaft
As i said earlier, i cant find any for sure stuff after searching so im asking here, any info will help.
Old 06-09-2013 | 05:48 AM
Just for the record it works.
Fly cut .080 P90 head on a l26.
Old 06-09-2013 | 06:52 PM
Did it get shimmed?
The common consent is that machining .080 and greater requires cam tower shims to maintain proper timing.
Old 06-10-2013 | 05:03 PM
Yes i did shim the cam towers as well as extra shims under the valve springs using the longer valves from the 76-78 datsun z's.
Cali79zx
07-25-2010 09:26 AM
NismoPick
06-11-2008 09:18 AM
livefromiraq258
03-31-2008 07:32 AM
ASA240z
06-27-2006 02:09 PM
280zExTURBO
10-10-2005 01:27 AM
Quick Reply: l26 with p90 head
