Mikuni vacuum connections:
Old 09-18-2011 | 06:04 PM
the_journeyman's Avatar
I've searched three different forums and can't find an answer.
I'm working on sync'ing or balance my triple Mikuni carbs. I've done this several times on motorcycles with just a vacuum gauge with great success. I know it's not a Unisyn or similar, but patience yields just as good results.
The vacuum advance for the dizzy is connected to #1 carb.
The middle carb doesn't have anything, and I can't get a vacuum reading on the port.
Third carb, can't get a reading.
I'm trying to connect to the same place the advance tube is connected to on the #1 carb, but I don't have the tall nipple like on the #1 carb.
What am I doing wrong?
Thanks!
JM
Old 09-20-2011 | 05:22 AM
On closer inspection, I removed some hex screws from the Mikuni manifold, and I found that I did have access to the intake runners. However, they are blocked with some type of semi-firm sealant material. It's soft enough I can press a knife tip into it. Is this normal, or did someone do this to prevent vacuum leaks?
One pic shows overall, I have the allen screws out, but you can't really tell much about them.
Closer pic - turns out it's not solid, it's a white-ish sealant looking material, but very stiff. I can get the tip of a knife blade to dig in.
JM
Old 09-20-2011 | 03:30 PM
theramz's Avatar
I have a present for you...
That's an asbestos blanket to sheild heat from the carbs. You need to replace the vacuum hose and make sure your advance is working with a timing light.
Old 09-21-2011 | 07:32 AM
I've done both of those. My timing is 10 or 12 degrees at idle, and advances as I bring RPM up.
The round opening with the white stuff inside in the intake runner was what I was asking about. I did know that is a heat shield to keep from boiling the fuel in my carbs.
I'm wanting to know if I can remove the sealant from the threaded holes in the intake runners and take a vacuum reading there and re-seal.
JM
Old 09-21-2011 | 08:18 AM
theramz's Avatar
JM
Now I see it. That is a possible place but I doubt if it is threaded.
Old 09-21-2011 | 10:26 AM
It is, I had to thread a hex-cap out, and found this. I just wanted to make sure it would be a good place to pull a vacuum reading ~
JM
Old 09-21-2011 | 12:24 PM
theramz's Avatar
I think that would b a good way to balance the carbs if you could install a vacuum port in three of them and compare readings.
Old 09-22-2011 | 05:17 AM
That was what I was thinking. I'll see about locating some type of port and remove three of the sealant plugs. I'm used to balancing with vacuum readings since I work on motorcycles.
JM
Old 09-22-2011 | 05:49 AM
theramz's Avatar
That's a very effective way to balance carbs. If you had 3 gauges you could do it in a minute, good idea!
Old 09-22-2011 | 08:04 AM
Yea, three would make it super fast and easy. I've just got the one though, it'll still only take me 5 minutes to get them right!
JM
Pklepka
06-28-2013 05:37 PM
vrocious
05-09-2010 07:00 AM
texasz
02-05-2006 04:28 PM
garnett
03-27-2002 07:23 PM
Quick Reply: Mikuni vacuum connections:
