my 280z shuts off while driving
Old 04-28-2008 | 02:44 AM
dainamikus's Avatar
I have an automatic 76 280z, it starts and runs.
the engine runs strong but feels like the fuel will stop going to the engine sometimes, and i cant really go over 45 mph.
if i try to drive it normally it will shut off
dosent shut off on idle... except after 2 minnutes it'll act like gas is not going into the engine choke a bit and then turn off...
but then i can start it up again...
if i leave the key on before starting, it makes a noise in the back under the car... from the fuel area i think... a buzzing kind of noise is that normal?
the best way to describe the way it acts... is that it shuts off randomly while driving.. please help me out thanx.
Old 04-28-2008 | 06:42 AM
daina mikus? are you a Lithuanian girl? lol. idk just curious
also, that buzzing is the fuel pump. you sound like you got a fairly serious problem. you could start by trying to check the fuel pressure. sounds like you need a crash course in cars and car maintenance though
Old 04-28-2008 | 07:16 AM
Welcome to ZDriver dainamikus!
If you haven't done so yet, buy a 240z-280z Haynes Repair / Service manual... lots of good info in there. Like Snw said, start diagnosing the prob by checking what you can... fuel pressure, sensors (and sensor connections), wiring, timing, spark plug tips (this will give you an idea of how the engine is running).
Old 04-28-2008 | 10:38 AM
theramz's Avatar
I have a present for you...
Yeah, get the manuals by all means and learn about your car. Before you rush out and buy a bunch of test equipment turn the key on and listen to the pump. If it makes a steady buzz it's probably ok. Actually it isn't suppose to run until you hit start, not that important. It might be as simple as the fuel filter needs to be changed. Add some injector cleaner to the tank and see if that helps. Welcome to Zdriver, you've just begun grasshopper!
Pilgrim
09-30-2018 06:16 PM
Domi's 75 280z
05-31-2015 01:25 AM
Brian Crandall
01-09-2013 07:47 AM
3XAZOWNER
07-17-2006 07:06 AM
ensmuns
06-19-2006 05:01 AM
