Oil Pan Gasket and Valve Cover Gasket
Old 06-09-2009 | 11:24 PM
Warpix's Avatar
Hi all, Just got a 1977 280z recently and I am looking into fixing it up a little and have already ran into some questions about changing the oil pan gasket and valve cover gasket.
Oil Pan Gasket
This seems to leak and I would like to replace it, but looking at my CLYMER shop manual, it seems that I'm supposed to raise the engine a bit with a hoist. Since I don't happen to have one of these on hand, I suppose I would have to rent one. So I would like to know if any of you had experience with this and what type of hoist is preferable.
And I'm not really sure why I have to raise my engine, so if anyone knows why I have to, please tell me, an answer to this would be nice.
Valve Cover Gasket
My CLYMER shop manual tells me that I have to ajust it while cold and then when's its hot. Does anyone know why this is? It doesn't make sense to me of why I would have to ajust the valve when its cold and again when it's hot.
Thanks in advance.
Old 06-10-2009 | 06:51 AM
Welcome to ZDriver!
You should be able to R&R the oil pan w/o raising the motor on a 280z. On the 280zx, it's a bit more cramped.
As for the cold & hot adjustment, that is for the valve lash, not the cover itself.
Toss that CLYMER manual and buy a Haynes manual.
Old 06-10-2009 | 05:33 PM
Warpix's Avatar
Thanks for the welcome!
Alright, that's exactly what I wanted to hear, guess I have to search for a Haynes manual then.
Thanks for the info and advice, I'll be sure to post after Sunday.
Old 06-10-2009 | 05:55 PM
also try tightening the oil pan bolts before replacing the gasket, might save you alot of head ache.
Old 06-11-2009 | 07:29 AM
Oh yeah... might want to try that first. < start with the easy? but that's... too easy! >
Old 06-11-2009 | 08:58 AM
260zturbo's Avatar
Stupid Hurricanes...
if u do end up replacing ur oil pan gasket u are going to have to retighten then after u run the car the first time.
Old 06-11-2009 | 10:19 PM
Warpix's Avatar
Thanks for all the extra input, I'll definitely make sure to do all of this, and hopefully all I have to do with the oil pan is tighten some bolts.
Z-EZ
01-11-2014 05:19 PM
Sixer
04-14-2010 05:39 PM
KasbeKZ
11-18-2009 09:25 AM
duowing
10-05-2007 01:03 AM
MetalTear17
08-10-2004 12:48 PM
Quick Reply: Oil Pan Gasket and Valve Cover Gasket
