Rebuilt Engine in a 1976 280z
Old 03-25-2011 | 12:20 AM
Krzydragon's Avatar
I have a 76 280z with a rebuilt engine,new plugs and Dist.rotor ect. The spark plugs keep getting fouled out and it smokes really rich. replaced the spark plugs and distrib. again. Still is running rich and sputtery. The timing was done by ear. Could someone please help.
Old 03-25-2011 | 08:04 AM
Welcome to ZDriver!
First, check ALL sensor connections to make sure they are secure and free of corrosion. The coolant temp sensor in the thermostat housing and the O2 sensor (if your car has one) are the main sensors that control a/f mixture. Also check your AFM. Under the black cover is a sweeper arm attached to a carbon track (potentiometer) to measure air flow. You can re-adjust it (we have a write up in the General Tech area).
Old 03-26-2011 | 11:58 AM
Krzydragon's Avatar
checked sensors
thanks for the info. While I was checking everything I found that someone had cut the wires on the water temperature switch. I have been looking for a replacement part but so far no luck. Any advice as to where I could get one?
mowermechanic
34
03-26-2008 03:50 PM
EatmyDust
09-08-2004 09:32 PM
Loggerboy666
04-15-2004 12:38 PM
Quickshift
04-13-2004 09:13 AM
Julven
07-31-2002 02:53 AM
Quick Reply: Rebuilt Engine in a 1976 280z
