replace vacuum advance?
Old 09-16-2011 | 06:14 PM
the_journeyman's Avatar
So, as I'm fiddling with my triple Mikunis, and reading on here, I come across info on the vacuum advance.
If I'm not pulling vacuum properly to advance my timing, I'm assuming tuning the carbs is useless.
Currently, my vacuum line is a thin clear tubing. The end on the carb is a bit hard and it slides on an off the vacuum port very easily. I pulled it off the bottom of the distributor and checked vacuum from that end of the line.
At first, the vacuum gauge barely wiggled. When I pinched the line tight against the vacuum port to help it seal, I started getting way better readings, but the were all over (probably because of the makeshift seal my fingers were helping make) the place.
I'm thinking I need to just replace that little piece of line to "be sure" it's sealing properly.
Am I correct? No advance could make it feel pretty anemic up high? Plus it's about $1 in parts.
Thanks
JM
reddoguh1
11-26-2008 07:34 AM
Fast240Z
11-10-2005 09:47 AM
zxrodster
09-02-2004 04:18 PM
Lee82280
04-02-2002 12:43 PM
twarr
04-27-2001 04:07 AM
Quick Reply: replace vacuum advance?
