Shifter T5?
Old 05-03-2004 | 02:42 PM
See the attached image. Nissan transmission on top, Borg Warner T5 on bottom.
The T-5 has a rectangle plate that bolts down with four small bolts. The shifter goes through this plate into a receiver below. There is no pin to hold the shifter in. The Nissan transmissions came in two types. The early transmissions 1974 and before were all 4-speeds (in the US). The later transmissions starting in 1975 were long tail transmissions and have the pin you describe as pictured in the upper tranmission.
Old 05-03-2004 | 09:25 PM
theramz's Avatar
I have a present for you...
Question oddball shifter
Originally Posted by bluesman1958
Thanks for the reply. The transmission I have doesn't look a thing like the photo. There is a little diffrence in the cast but it looks pretty much just like the four speed. There is the diffrence in the shifter still. It's like the two prongs that support the shifter are just a little shorter on the five speed. I haven't seen another shifter like it advertized or anything. I tried the four speed shifter in the five speed and it looks like it may work. Did you have to push the shifter down in the motion to shift to reverse in the five speeds?
I've seen the spring shifter your talking about. It is the only year ('81) I came across that had it. Only the ball end bushing is the same.
CrazyLotusTT
11-17-2015 08:45 AM
joselitopr
10-20-2014 08:35 PM
ThermalWake
02-07-2007 06:27 PM
kevtt
03-11-2006 06:37 PM
CrazyLotusTT
08-10-2002 11:37 PM
