stupid drain plug.
Old 12-25-2006 | 09:13 PM
Captain caveman's Avatar
stupid drain plug.
I'm getting irritated. Tried to remove the drain plug on my oilpan. Busted one of my sockets on it. what's up. Did any of the 70-83 have drain plugs have strange threads. Anything I can do to loosen this?
ah, just googled stuck bolt. lol, slap myself in the head. Friend says he has loctite that'll remove it and if that doesn't work I have a torch. Nvm for now
Old 12-25-2006 | 09:20 PM
Busted a socket on it?!?! Get better sockets. Spray some good penetrating oil on it & let it soak for a while.
Old 12-25-2006 | 09:21 PM
second^^^ and maybe some PBblaster
Old 12-25-2006 | 09:36 PM
BigEkak1941's Avatar
If the bolt is that tight the PBblaster is a good suggestion. Also I would recommend using 1/2" drive sockets (they are stronger), and use a breaker bar with an extention. That should do it and I wouldn't use a torch unless you want a major problem. I broke a 3/8" 14mm socket on the bolt holding the rack & pinon in, and then used 1/2" socket with no problem. The 3/8" was a Craftsman so you can see the bigger the socket the stronger. Good Luck and I hope the rest of Christmas was better.
Old 12-25-2006 | 09:48 PM
yeah and go slow or its possible to break teh bolt in half...
Old 12-25-2006 | 11:17 PM
emo236's Avatar
confuzed member
Use leverage. you'll get it.
Old 12-26-2006 | 01:12 AM
sigh, Tried a stronger socket and it's stripping it. I'll try that pbblaster tommorrow. Sigh, wasted hours just trying to change my oil, lol and I just realized I bought 5w30. I think I need 10w30 and this motor has a little blowby I believe so using a thin oil is a bad idea.
Old 12-26-2006 | 04:03 AM
BigBirdsZ's Avatar
thats cuz u also used the wrong size socket on it at at sum point if it strips more bust out the good old monkey wrench then buy a new drain plug
Old 12-26-2006 | 07:26 AM
Has your engine been sitting in the bottom of the ocean for a couple years? It shouldn't be this hard to loosen the oil drain bolt. Is there a lot of rust around the plug? Are you remembering "leftie loosie... rightie tightie" ???
Old 12-26-2006 | 09:23 AM
skittle's Avatar
Taste My Rainbow
^^^^ lol lefty loosie righty tighty...
Old 12-26-2006 | 11:05 AM
emo236's Avatar
confuzed member
it's not that far fetched. It happens more than you probably think. 2nd on that, make sure you have the right size socket, enouhg leverage, and you're turning it the right way.
Old 12-26-2006 | 02:36 PM
I'll try the mokey wrench out after work. See how that does
Old 12-26-2006 | 03:23 PM
use a pipe wrench too, the are an all size fit! and at some quicky lube places they use impact guns to tighten the plug, usually screwing the thing up, either the threads or the head of the bolt, get your engine good and hot first as well, it will help with the removal
Old 12-26-2006 | 04:06 PM
skittle's Avatar
Taste My Rainbow
Just Be Carefull Of The Hot @ss Oil When You Do Get It Out That Stuff Will Make You Not Happy.
Old 12-26-2006 | 05:40 PM
umm... i dont know aout you but i let my car sit adn cool before i change my oil.
Old 12-26-2006 | 07:05 PM
well you're just a wimp then
Old 12-26-2006 | 07:29 PM
emo236's Avatar
confuzed member
I do a lil bit, but you want it to be somewhat hot b/c then it's thinner and more will come out, thus a better oil change.
Old 12-27-2006 | 01:07 AM
well yeah i dont let it get cold... only so that if the oil splashes on you cause it will... theres no burnage... only ooch thats kinda hot.. or very warm... then it almost feels good. lol
plainwhiteZ
02-16-2012 12:36 AM
seafbyrd
04-20-2004 01:40 PM
mnelsonz
09-26-2002 11:45 AM
AlansZ
07-23-2002 11:02 PM
AlansZ
07-01-2002 07:05 PM
