transmission swap
Old 09-16-2002 | 12:57 PM
Re: transmission swap
Yes, but I heard that the tail end of the ZX transmission is a little longer than a 260Z. You might end up having to have the 260Z driveshaft shortened for you.
Also, the gears are a little taller (especially 1st) depending on what year of ZX. So swap the rear differential too. Try to see if it is a 3.9 gear first. If not, then its probably a 3.54, the same as your 260Z.
Old 09-17-2002 | 03:47 PM
1977-79 have the same 5-speed ratios. 1st is 3.3:1
1980 has the same but with a slightly higher 5th gear.
1981-83 5-speeds start 1st gear at 3.0:1 ratio but has the highest 5th gear of all the old 5-speeds.
The 280ZX turbo T5 5-speed has a very low 3.5:1 1st gear.
4th gear is always 1:1 ratio
Some may say their car pulls hard in 1st gear with a 3.54 rear end, but have they ever driven a car with a 4.11 rear gear? :-D
I have... and it makes a huge difference going from a 3.9 to a 4.11 It pulls so much harder and more suddenly
BlueKitsune
06-20-2012 10:14 PM
BlueKitsune
04-24-2009 10:58 PM
JBs280Z
07-19-2007 07:38 PM
fokker300ZX
10-25-2004 12:40 AM
762x54r
03-25-2002 02:47 PM
