1977 280z running lights wiring
Hey guys, I've searched and searched but couldn't find an answer. I'm relocating my turn signals to around my headlight using led's. Does anybody know whether the green with the white stripe is the running light and the solid green wire going to the turn sign bulb is the turn signal wire or vise versa? My battery is completely dead and won't hold a charge so I cannot test the wires with a test light. Any help will be appreciated! Thanks in advance
By the schematic, passenger side signal wire is GB, and drivers side signal wire is GR. GW is the marker light and B is obviously ground.
scroll down to second drawing.
http://www.zeddsaver.com/wiring/1977...20drawings.pdf
