1980 280ZX Won't Start
Old 11-25-2002 | 09:27 AM
Re: 1980 280ZX Won't Start
Having the crankshaft pully come off is sort of like having a timing chain break. (if that ever happens) Your pistons continue to go up and down while the valves will come to a slow stop. If that is actually what happened, then all of your valves are bent, and all of your cylinders have hard indentations where they hit the valves. I bought a parts truck with an L20b in it that had this happen to it. If that is the case then the techs at Nissan were right. You need a complete rebuild. Most likely you don 't need a whole new engine, but 6 brand new pistons, new valves, valve guides, cam and followers would be a good start.
Your valves are probably bent to one side a little and not sealing when the cam lets tension off. Therefore your cylinder pressure would be extremely low or maybe none at all. that is why it won't start. Do a compression test to verify this.
frawleyfly
09-29-2013 09:24 PM
280zman
01-24-2013 02:31 PM
moorebl
04-14-2011 04:28 PM
EatmyDust
05-12-2005 09:03 PM
zxrick
09-21-2004 08:25 PM
