260z swap
Old 11-16-2003 | 08:59 AM
Creator's Avatar
-RB25DET / RB26DETT (skyline motors) would yield the best stock horsepower (290+hp), plus modern engine management. But it would also cost you an arm and a leg unless you have a motor in a junkyard somewhere.
-RB20DET (Nissan 180 / 200sx motor) would give about 220-250hp, and would also be about 40-60lbs lighter then the RB25DET / RB26DETT, but these RB20DET can only get up to about 280-300hp reliably (this is only from what i've heard, tuning mags have taken the block upto 400hp, but i wouldn't trust it as a daily driver at that power); but this will also set you back a fair bit of coin too.
-L28Turbo very cheap, good power (tuneable to 300hp without much trouble), but just as heavy as the RB25/26DET (if not heavier, from the iron heads/etc). But they're everywhere.
All of these motors use stock engine mounts, and tranny mounts, if you change the tranny you may need to shorten the drive shaft, and if you switch a carb to FI, you'll need to get an FI Gas tank (for the fuel return line).
It all comes down to cost, and what you're looking to get out of it.
Mino
11-10-2013 04:40 PM
DeathByNissan55
23
03-26-2012 10:26 PM
Mhinrichs
285
05-02-2008 09:19 PM
Gargamel
07-07-2001 02:49 AM
Quick Reply: 260z swap
