280Z Strut bar options
Guest
Posts: n/a
I recently aquired a 1975 280Z, look under rides, page 6 under Timberwolf to see it. Anycase It has a turbo ZX hood on it. If you are familiar with this you know that on the under sife it has a wind tunnel that hangs down about 2-3 inches. When the hoos is closed, it is exactly when my strut bar would be. I love the hood scoop, but would also like to have a strut bar.
Does anyone know of another manufactuer of strut bars for a 280Z besides Motorsports Auto? I need it as flat as possible, maybe at the same elevation as the towers themselves.
Guest
Posts: n/a
Re: 280Z Strut bar options
Thanks for the thought, however I made my own third option. I took a dremel tool and modified the ZX hood scoop on the bottom to allow clearance for the strut bar. Looks good and handles very nicely. I am still undecided if I should install the rear strut bar seeing as the roll gage really does the same thing in stiffing up the frame. If I install both it may look a little crowded, not to mention I can haul nothing bigger than a cell phone in the rear of my Z.
Guest
Posts: n/a
wow i never realized how well a ZX hood works on a Z, i know the mounting on the hood is different, so did you have to use the ZX hinges?
sweet car man
-Steve
http://www.geocities.com/stev240z
sweet car man
-Steve
Guest
Posts: n/a
Actually it is not the hood but rather the ZXT Hood scoop/ RAM air device. It was designed to shift air directly over the turbo, however this car does not have a turbo. It is there for looks only.
Cancel my last post also, I thought I had figured out the strut bar equation but it appears have not. Still not enough clearance.
OxZCar
01-25-2010 01:39 PM
Bleach
10-27-2004 03:30 AM
