280ZT Fuel/Wiring Issues?
#26
I was beginning to think about what you said and maybe my battery is just on it's way out or needs to be fully charged. At this point it's probably about a 3-4 year old battery, but it still seems like the battery should last longer than that, but it's been a good while since the battery had been in a running car and I've never actually charged it.
A few other things I came across. The inhibitor wire that goes to the ECU I had removed, but I keep coming across posts saying to ground it, and I think I need to plug the ZXTs Fuel Pump Modulator into the harness. I don't know if that will make a difference, but I had that still connected back when I was running the Z31 setup on my 280ZXT. I figure I'll get that hooked up, either charge the battery up all the way or throw a new one in there, and if still no luck, I'll just start going through the entire EFEC section of the Z31 FSM to test the ECU and it's components.
emo236
03-23-2005 09:36 AM
