5 speed 1976 280z
Old 02-27-2013 | 08:57 AM
Pez's Avatar
Pez
5 speed 1976 280z
I didnt think that the stock transmission in a 1976 280z was a five speed, however mine has a 5 speed installed.
The issue is that I need to replace the clutch, and I'm unsure which clutch will be appropriate. My thought is that the PO replaced the stock transmission with a later, perhaps 280ZX transmission.
Any advice on how to tell which transmission I have, and thus which clutch I need?
Old 02-27-2013 | 10:07 AM
Clutch type is dependent on flywheel, not transmission. And unless you have the 280ZX 2+2 / Turbo 240mm flywheel, you just need the stock 240Z - 280Z 225mm clutch.
Lots of info on this...
https://www.zdriver.com/forums/280zx...starter-31417/
2+0 N/A = 225mm flywheel
2+2, 2+0 Turbo = 240mm flywheel
Clutches cant be interchanged between the 2 as they wont mount up, you you must have the right T/O Bearing collar for the right clutch.
2+0 N/A = Short collar
2+2, 2+0 Turbo = Long collar
(I might have that backwards on the T/O collar, I'm half asleep.)
You can also use any flywheel/clutch on any L engine with any manual trans starter.
Old 03-04-2013 | 03:32 AM
Pez's Avatar
Pez
Rock - thanks!
Bucket280z
07-26-2012 01:03 PM
moparmusclecars
12-24-2011 06:49 AM
ertxc
08-18-2009 11:20 PM
mowermechanic
34
03-26-2008 04:50 PM
Quickshift
04-13-2004 10:13 AM
