5 speed, clutch, flywheel
Old 10-28-2002 | 09:10 AM
Re: 5 speed, clutch, flywheel
If you are looking to replace your 5-speed to get one that can handle 220hp, then don't bother. Even the factory Datsun 510 transmisisons can handle that horsepower. Your 77 280Z 5-speed should be able to handle somewhere around 275 horsepower and I'm sure some people have used them in even more powerful turbo engines.
If you want a simular gear ratio replacement though, go for the 1977-80 Z and ZX. The 81-83 ZX is closer ratio, but 1st gear starts out higher. Only use that transmission if you have a 3.9:1 or lower differential.
The 2+2 flywheel has a wider contact point. That gives you some extra grab, but is probably not nessisary for your car. Go for a regular coupe flywheel for the least amount of horsepower loss through the clutch.
VenomousZX
06-18-2010 11:16 PM
sticky280zx
03-11-2008 12:28 AM
allmotor300z
02-03-2005 08:07 AM
tsefreeflow
05-16-2004 12:30 AM
