Anyone want custom kickpanels for speakers?
Old 04-25-2001 | 09:37 PM
Ghostz's Avatar
Well, maybe one more
From: Far away, locked up from anything interesting, almost in the dead center of the US
Re: Anyone want custom kickpanels for speakers?
Ahem, nitrous only DESTROYS an engine when incorrectly used. In some instances, like in a turbo model, nitrous can be a massive help, it acts sort of like an intercooler while using it, allowing you to run a slightly higher boost. Of course, if you have a Z with 220,000 miles on it (like myself) you should not consider the big 'N' unless you totally rebuild your engine to ensure that it will handle the added stress. Those who 'BLOW UP' their engines while running nitrous either went way overboard (see said 250 hp shots that you can get from Zex) or didn't do any prep work on their motor before they installed the nitrous. It is just a matter of learning to properly use it, not saying it is easy.
Ghost
Niku-Sama
10-10-2008 02:50 PM
livewakesnow
15
06-29-2005 11:14 AM
zthang0634
05-20-2005 11:17 PM
cm3
09-29-2003 06:43 PM
280zxlimited
05-22-2003 10:26 PM
