Autocross Alignment
Guest
Posts: n/a
Autocross Alignment
For those of you setting up an autocross car, here are the "ideal" alignment specs. Basically, you purchase all the hardware to allow enough suspension adjustment to hit these numbers:
Front
Camber - 3.5 degrees negative
Toe - 3/16" to 3/8" out
Caster - 6 degrees positive
Rear
Camber - 2.5 to 3 degrees negative
Caster - not normally adjustable
Toe - 7" or narrower wheels - stock toe setting, 8" or wider wheels 3/16" in.
Ride Height
5" front, 5 1/2" rear.
John Coffey
johnc@betamotorsports.com
Front
Rear
Ride Height
John Coffey
