Brake Light popping on
Old 12-12-2002 | 02:03 PM
Re: Brake Light popping on
I don't think there is a sensor on the pads on a pre 84 Z-car. The sensor is on the brake fluid in a 280ZX, and only on the parking brake arm on all older Zs. The problem is most likely your fluid is low. When you press on the brake pedal it pushes some of the fluid into the system and the level goes down just to the point of where the sensor turns on. As for replacing brake pads, maybe you also added some fluid... or your sensor coencidently broke! :-D
Dirt Winston
03-26-2013 09:26 AM
joel280zt
08-02-2012 07:10 AM
Turbo86
01-15-2007 04:45 PM
romeopitbull
08-29-2005 11:50 AM
romeopitbull
08-27-2005 09:12 PM
