Brake lights out
Brake lights out
Just noticed the other night that my Brake lights are not working when pressing the brake. I just bought the (1978 280Z) Z at the begining of July and not sure now if they ever worked. Checked the Bulbs and all seem to be in good shape. Same with the fuses.
Other maybe related problem???
1. when I turn on the Right turn signal It does not flash. The light will come on and stay on. Left turn signal works just fine.
2. When I turn on Hazard lights they dont work either. infact when I flip the switch the Volt gage kinda freaks out.
Please any suggestions would be welcome my inspection is due THIS MONTH.......
Replaced Brake light switch and brake bulbs... Got one to come on however it is not the BRAKE light it is the lights on switch.
I did find an after market bulb socket installed kinda shotty (passenger side). Seeing if I can replace that tonight.
so still no "Brake lights"
Are the lights in the Z in series? the reason I ask is when one goes out it seems to affect others.
Originally Posted by hoov100
is the little rubber plug on the brake pedal still?
Replaced flasher unit (hazards still dont work)
replaced Bulb socket on passenger side. Now with that, when I turn on the head lights both filiments (sp) are on on the passenger side are on. Still no brake lights when i press the pedal.
volt ohm meter reads zero resistance when wires are unplugged and open and full resistance when no brake applied. so i tested the resistance with just the two wires and nothing is passing.
I think the prob is wires under the dash some where....... no fun
