brake lite????
Old 08-16-2002 | 11:40 AM
Re: brake lite????
hehe... no, its not bad if you don't care about stopping! Try topping off your brake fluid and see if the light stays off.
You should put in your new brake mater cylinder. You need to bench bleed the thing first. Then put it on and hook up your metal lines. Then put on all your new rubber brake hoses. Be sure to check to see if your car uses "inner" rubber hoses. If so, you may have 6 hoses, not just four. My ZX has 6 total hoses.
THEN, bleed your entire brake system. Let us know if you need clarification on any of those steps.
Old 08-16-2002 | 01:37 PM
Skully's Avatar
Re: brake lite????
me and my dad do it this way......
get som1 inside the car to pump and som1 releasing the bleed nut on the caliper.....
pump like 3-4 times then when it gets hard hold the brake down open the valvle till the brake goes down and air comes out then close the valve......repeat like that till no air comes out.......
Old 08-16-2002 | 02:30 PM
Skully's Avatar
Re: brake lite????
ALOT of air ALOT...u can do that to put new oil in but it wont jus push out the iar you havta do that....
Old 08-17-2002 | 04:35 PM
Skully's Avatar
Re: brake lite????
well ok wutever worked for me awsome and my dad been doing it for over 20 years.....do whatever u want.....
Old 08-21-2002 | 08:39 PM
Skully's Avatar
Re: brake lite????
ok but dude why cant u just let this one go we always do it and we get all the air out in like 5 minutes.......
Old 08-22-2002 | 07:40 PM
Skully's Avatar
Re: brake lite????
yeah any road you take as long as you get the job done...
theramz
04-20-2012 04:14 PM
TEDS280Z
05-13-2006 06:20 AM
marvinbwest
11-30-2005 10:07 PM
AdamX2
04-29-2003 07:10 PM
lil_racer_tony
07-31-2002 12:23 AM
Quick Reply: brake lite????
