cam.
cam.
im looking to upgrade my cam. i dont want anything too radical, but i do want more pep but not completely kill my gas milage.. any suggestions on about the lift and duration or stage of cam i should go with.?
MSA cam stage I: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2001
MSA cam stage II: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2002
MSA cam stage III: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2003
MSA cam stage IV: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2004
MSA cam stage V: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2005
MSA cam stage VI: http://www.thezstore.com/page/TZS/PROD/PEM01/10-2006
Info about stock Z cams:
http://www.geocities.com/bruskiz/ZCamSpecs.htm
If you don't want anything radiacal... go w/ a mild cam.
Originally Posted by ThermalWake
do i have to replace all valvetrain as well?
Originally Posted by MSA
Note: Cam is ground on a new billet. Warranty on cam shaft requires use of new rocker arms, proper springs, proper lash pads, and proper professional installation.
Also... depending on which cam you choose, you might need stiffer springs.
Originally Posted by BigBirdsZ
i going to port and polish my head, and i want to go with the stage III cam, this cam would go good with a lite port right?
I had the 274 duration cam (stage 2?) and it was pretty good. It shifted the power band up by about 500 RPM on stock electronics, but Im sure it would have run much better on a properly tuned megasquirt. I threw it in with the old rockers without any problems, but your experience may vary...
If you are seriously going to port & polish your head, do not polish the intake side. If the surface is too smooth on the intake, the fuel will not atomize properly, and it will be slower than it was before. What I did with mine was ported the intake side like a bitch, and smoothed out the exhaust side. THen I ported my exhaust manifold to match that. I actualy roughed up the intake side a little. I didn't port the intake, just cleaned it up with sandpaper.
