Compression ratio
Guest
Posts: n/a
Re: Compression ratio
Zmedic,
you might want to play with a Lengine program you can find your compresion ratio, and determine which octane you'll most likely need. I'm not too sure about finding out what octane you need, but the higher the compression ratio the higher the octane needs to be like 10:1 compression ratio 92 octane would be good
here's the link to download the L engine program, this program is pretty sweet here, click on tech section
http://www.zcarclub.com.au
zya
Yuichi
Zdriver.com
zya
Yuichi
Zdriver.com
