Cracked Injectors
Old 04-20-2001 | 06:17 PM
Darrel's Avatar
Registered Zee Racer
Re: Cracked Injectors
injectors-- the pintol caps can be replaced. If you can find a place that cleans and tests them in your area, they should have some.
injector connectors--- If you can go to a pick and pull in your area look for saab cars. They have the same connector only it is the quick release type. better to unhook when working on the injectors. Or you can go to your local import parts place. See if they can order directly from bosch. They are the original supplier. I don't have the part number handy, but it comes with the rubber boot, connector(quick release type) and new wire crimp ends.
And don't forget new seals.
If I can I will post a couple pics of the inj and part number on my ride page.
Good luck.
Darrel
82zxt
<P ID="edit"><FONT class="small"><EM>Edited by Darrel on 04/20/01 05:19 PM.</EM></FONT></P>
Old 05-06-2001 | 07:38 AM
ZmeFly's Avatar
professional Z car owner
well you could go that route but buy the time you do all the you could get a comeplete set of new injectors from sherco auto. for like 120 dollars
just my .02
james
watch out here comes my Z V8 powered and ready to roar
Sam
04-19-2011 10:40 AM
Carl's Z
04-09-2007 11:31 AM
ZMaster
12-04-2005 04:50 PM
Fast240Z
09-26-2005 05:39 AM
hotforz
03-27-2005 10:11 PM
